20x10 Offset
Discussion in 'Ford Raptor Chassis - Suspension - Wheels & Tires' started by Milez28, Oct 28, 2012.
  1. Milez28
    Milez28 New Member
    Oct 2, 2012
    80
    0
    6
    Houston
    Ford Raptor
    Black
    I notice a few people wanting to know the same information about this size wheels and the repeted question is what offset to go with for 20x10 wheels. I used the wheel offset calculator to determine these values referencing the stock wheel specs are 17x8.5 with 34mm offset. I hope this helps but I would like to hear (and PLEASE POST PICS) of others that have went this size and what offsets they have.
    http://www.1010tires.com/WheelOffsetCalculator.asp
    The wheels I'm considering come in -12 or -24 offset.
    Inner Clearance = the inside of the wheel to the strut housing
    Outer Clearance = position of the outside edge of the wheel
    For -12 Offset:
    Inner clearance is 27mm (1.06in) more than stock
    Outer clearance extends out 65mm (2.56in) more than stock
    For -24 Offset:
    Inner clearance is 39mm (1.54in) more than stock
    Outer clearance extends out 77mm (3.03in) more than stock
    That's quite a bit of change from stock and since the raptor is already wider than a F150 I really don't want to go too much wider stance than that. I can imagine squeezing those narrow toll booths, parking garage booths, etc..
    I'm thinking a 0 offset would be a good for this size and not stick out too far as it would yield about .5in more inner clearance and stick out about 2in more than stock..
    Feel free to share your thoughts, specs if you have this set up, and pics
  2. sinktheboat
    sinktheboat Member
    May 15, 2011
    124
    0
    0
    kiwi in dubai
    2012 Raptor SCab
    Tuxedo Black
    i have 20' with 0 offset and 12.5 x 35 nittio trail grappler and it just rubs at full lock to left.
    I'm on mid perch the tyres are about 1' taller than stock when stood side by side somehow.
    I've ripped flare off the back side of front left wheel 3 times now, sliding into sand track on short cut to work ! Sikaflexed flare hard up and back now sweet...https://www.dropbox.com/s/csut5amfouw3z3u/2012-10-27%2017.24.41.jpg
  3. sinktheboat
    sinktheboat Member
    May 15, 2011
    124
    0
    0
    kiwi in dubai
    2012 Raptor SCab
    Tuxedo Black
  4. RaptorPeru
    RaptorPeru New Member
    Sep 10, 2012
    14
    0
    0
    Peru
    2012 Ford Raptor
    Black
    20 x 10? what wheels? looks like hres or adv.1
  5. Milez28
    Milez28 New Member
    Oct 2, 2012
    80
    0
    6
    Houston
    Ford Raptor
    Black
    Just did mid perch then installed the Fuel Hostage Black 20x10 with -12 offset. 35x12.5x20 Toyo Open Country MTs.
    I gotta say it REALLY changes the stance of this beast..
    I will try to get some pics but I lost my iphone recently and am on my cheap back up phone..
  6. justvettn
    justvettn Member
    Feb 13, 2012
    122
    0
    0
    Toronto
    Ford Raptor
    Black
  7. Raptor925
    Raptor925 New Member
    Sep 15, 2017
    3
    0
    Oakley
    2013 ford raptor
    Oxford White
  8. Raptor925
    Sep 15, 2017
    3
    0
    Oakley
    2013 ford raptor
    Oxford White
    Did this setup rub at all?
