I believe you need an electronic ballast for the 4ft LED Tubes to work. If you install the tubes and they don’t turn on you might need to swap out the ballast. It is a really simple swap. Push in connectors make the swap easier when re-wiring the ballast.
Also, some 4ft LED tubes don’t require a ballast, I would probably stay away from those and just go with Phillips which still require a ballast. You can pick them up at home depot. I went with the 4100k. Nice neutral light. Not to yellow or white bluish color. Really enjoy the lighting it gave my garage.
