Hello raptor fans.
I need help with a problem I have with the AC fan. I would start the truck and the fan will stay on. The AC is off but the fan stays on. It won't turn off. I disconnected the battery to see if it would turn off, but it stays on. Hope I can get some help.
Thanks
Discussion Starter #4
Will that part help out with the fan to stop while in OFF and also the low and high settings on the FAN?
Thanks
I believe that sensor gives the computer the pressure reading on the high pressure side of the compressor, when that pressure goes up, the computer turns the fan on. I figured it was something free, to try, to see if it changed anything. Without having a scan tool to see if the fan is being commanded to turn on, it's hard to guess what it is.
