Hi. Ever since I jump started my truck the center display screen and radio does not work. I thought it was a safety feature as my old battery was going bad. But even after I replaced the battery. It's still dead. So I have no stereo, nav, or backup camera. The heater and a.c. still works tho, but only with the buttons. Voice activated features are gone too. Any trouble shooting tips. Which fire should I check? Thanks all
JZ,
You didn't specify your Raptor's year so this is kind of a guess. I have a 2014 Super Crew and my owner's manual shows a fuse panel in the right front passenger kick panel; your vehicle may differ depending upon the year/model. The fuses you should check are: #9 (10A for radio display, GPS module, and electric finish panel module), and 26 (5A for radio frequency module). That's all I see for anything to do with the radio or display. Number 19 is the audio amplifier, under back seat, but it shouldn't keep the display from working but since you're in the box may as well check it. Anything further you might need a wiring diagram for; I don't have one so can't check it for you. Not a clue how you could have blown just those fuses unless you arced something.
I recently had an incident with my Raptor on trip with a crank no-start that turned out to be a fuse with an burned/carboned post. I'll make a detailed report to the general population when I've checked things a little more thoroughly and know I've got it fixed.
Hope this helps,
LZinAZ
Sorry to revive an old post, but I now have this exact same problem in my 13 screw. I tried the fuses mentioned and all of them are fine. Mine occurred after getting it back from an oil change. Same symptoms as the OP. Anybody have a solution?
