1 - 1 of 7 Posts
If you go with the deavers go with the +2, that way you maintain factory ride height and lose the 2" block.. also, you should pair your deavers with the hydraulic bump stops from SDHQ.. using the factory bump stops with the deaver set up is a bad idea! There are other frame reinforcement options SDHQ has developed that you should include.. its about 4Gs with for parts and install.. but its worth it.. huge upgrade..
1 - 1 of 7 Posts
You have insufficient privileges to reply here.
