Ran the dyno today after installing new injector dynamics 1kcc replacement injectors. Was pulling p0172/0175 codes running rich. Found a leaking injector on cyl 1. The injector dynamics set I got is amazing. Went from 62 lbs to 100lbs injectors, tuned at my higher altitude (Denver,CO) and pulled 8psi from the pro charger running 535hp at the wheel. What a pleasure to drive!!! I have a vid from the pull if anyone is interested.
