As of right now I have one question. Is there a way to disable the warning that comes on the cluster when I go above 60 mph that tells me to drive safely.
Get a tuner. Plug it into the OBD2 port and select the “speed limit” function. Raise the limit to 140mph
Sounds like "My Key" has been activated on the key you are using. If you have a second key, start your truck with the second key, go to the settings menu , and see if it is a " Admin Key " . If it is, follow the steps to delete My Key settings on all keys. The instructions are also in your owners manual. If you do not have a second key or neither key is an Admin key, any Ford or Lincoln dealer can delete the My Key setting. The dealership I work at charges $ 55.
