1 - 1 of 1 Posts
hello i need some advise
am currently working on a ford raptor Thailand modal 2019
its is all fine it idles well and its new with up to 65000km in millage but its started developing Christmas tree in the dashboard and latter ABS light came on and latter when gear is engaged it stalls immediately its an automatic transmission. Could the abs be the problem or the torque convertor
codes
abs
Code: U3000 - Control Module
Additional Fault Symptom:
- Calibration/Parameter Memory Failure
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
Module: Antilock braking system
IPC
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Instrument Panel Control Module
1 - 1 of 1 Posts
