21 - 23 of 23 Posts
Premium Member
Discussion Starter #21
No worries sir, just trying to pay things forward. your doing a great job on that gen1.
I appreciate that thank you, I will do the same where I can in the near future with anyone who needs it, Thank you its like being an operator in the military just seems a lot simpler, the hardest part is waiting on parts, the rain and flooding that wont let up and running down all the small stuff such as screws, bolts and such,
Premium Member
Discussion Starter #22
Will upload pics tomorrow on my progress, been working on several areas:
1. I had help with the front end under carriage with releasing the suspension and stablizer bar that all is unhooked and looks like a worm bucket of unhooked rusted f150 non Raptor parts and then put the battery back in the truck kinda hard to keep the battery under the hood right now due to the scrapped right upper rail. once connected I put the key in and floored the brake and switched gears to nuetral which finally allowed me to both use the brake pedal and also switch gears as previously the computer would not allow me to do it because the truck has been stuck in 4x4 mode, off road mode and hill descent mode. once I got everything on the dash hooked up last week I was able to program the truck to factory specs and do flash upgrades which reset all of that and I only had hill descent and off road mode on...
Even remotely I was not able to bypass or turn off hill descent or off road modes, So I had help with loosening up the suspension and stabilizer bar and then help with turning the steering wheel where the red stripe is on top and then releasing the brake pedal and switching gears back to park. from there I hooked up my digital maintainer to the battery and ran the remote proceedure with my Autel and I was finally able to bypass hill descent and off road mode and turn it off. however the same problem I had with 4x4 mode is with these two as once I am finished doing what I want to do remotely the bypass shuts off and reverts back to on position for both the hill descent and off road mode.
But I am at peace knowing that I knocked one of the two birds out and I know that once I get the aux upfitter switch and turn both modes on and then hook it up and turn the key and press both buttons off that they will stay off like the 4x4 switches did from L to H or H to L forgot which one it was in but it was stuck in the one you are not supposed to do daily driving in. its been a week since I hooked up the dash switches and I already forget lol...
2. I had some help with the lower right side sub frame bumper rail with holding it and removing it once I grinded it off., I tried out some auto dismantling blades for my sawzall that firemen use and they cut like butter better than any lenox or dewalt blades ever did for metal I was impressed. I used one to cut 6" away from the welds and was able to cut most of the sub frame rail off. which was a blessing since it was hard to grind in places where I could not move the ac or trans hard pipes. I then cut and grinded the 6" down to 1" and put Por15 on the last 1" and around the frame opening in case it starts to rain again as lately these past two months its been nothing but rain and flooding and spot rust messes up clean welds and why sand it down its a lot better to lightly sand the Por15 before welding.
I did it this way because whomever welded the beads for the sub frame bumper did a really poor job and you have globs everywhere. and I knew the best way to know that I am not grinding into the actual frame would be to look inside the hole.
So tomorrow God willing providing that He allows the rain to stay away for another day I will take my torch with one of my yellow canisters and heat up the end of the frame on the front and take my metal working chisel, hammers, picks, and my grinder and first break away the final 1" of the sub frame leftover metal and once out I will lightly grind the outside of the frame which will take about an hour and half as those weld globs are big and bad job. after that I will switch grinding discs and grind sand the outside all the way around, and then do the inside where the 1" leftover metal was. depending on the time of day and providing the weather is still nice with the rain hiding I will have my new friend come hold the sub frame bumper piece and line it up and I will take a 2 foot 2x4 piece and place it on the front and tap it in with my metal working hammer into place until I feel that 1" all the way around is inside the frame and is snug. from there while he holds it I will place two 25lbs welding helpers to the bottom of the frame to hold it in place and have him let go.
Then its all about taking your time, leveling, measuring etc. not just the two bumper pieces of the sub frame but also lining it up for your lower radiator bracket. there is a saying somewhere measure twice cut once or something like that...
Once I am ready for my first go I will have my friend hold the sub frame bumper and close his eyes and I will spot weld four areas and tack them into place.
I will then make sure the lower radiator bracket is lined up perfectly or the best its supposed to be and if so then I will remove it and proceed to weld the sub frame bumper piece.
Also note that the left side upper rail welds on the lower part that fits into the lower radiator bracket will not be welded into the lower radiator bracket and will just sit inside the new one until a later date. as the sub frame bumper pieces are important and are like a foundation for a concrete slab of a home. and takes care of 50% of your hard work for you now you can frame a home and still be lopsided but it would be the framers fault not the leveled concrete,
Once the lower tie bar radiator bracket is snug in place and leveled on both sides the insulators and bolts on each side will go in connecting and securing each one of the sub frame bumper rails into place.
The reason why you do not weld and secure the left drivers side upper rail into place is because from this point everything else needs to line up perfectly and spot weld, test fitted etc. and all line up perfectly as the rest after the lower tie radiator bar are critical pieces for your front end.
In closing, I will place most of my focus on the right side upper rail and fitting, securing, welding and riveting to specs., then let the bottom sit on the lower tie bar like the left side will be. then most likely will be drained and need a couple days off to rest my spine and when I continue will proceed to fit the Radiator bracket, and other small pieces we all have on our front ends of our Raptors and once everything lines up into place I will mark the lower tie bar with a silver sharpie and unbolt everything and have my helper take it off. and then we will proceed to line up the bottom and tack weld each side and then weld it.
Note that if you ever need to replace your lower tie bar, If you look at your current tie bar the two fins of metal that comes up on each side that are welded on your upper rails lower sections know that the fins do not come welded to your lower bar and they come as separate pieces and your lower bar has several notches on the bottom for you to slide your fins over and once you line it up with your marking you are good to weld. also note that all Ford OEM parts like this comes powder coated and you will need to lightly grind sand the powder coated area that lines up with your test fittings as it will be a lot better weld on metal to metal. and say after a couple minutes of your finished product of your welds I would highly suggest using a pint of Por15 on it you will only need 1 quarter of the pint. and depending on your Raptor choose the color to match your sub frame, upper rails etc. for me I am using semi gloss black it matches my powder coat but I painted over all of my powder coat to rust proof it.
Premium Member
Discussion Starter #23
i have front and rear lights from my gen 1 along with the oem SVT front and rear floor mats all in great condition, you just pay shipping. I am located in BHC AZ 86442-4414.
send me your paypal I was thinking I use the front lights for mock ups being that I am rebuilding the front end. also have not checked up in the diagrams but does your Raptor have headlight mounts or do they just float anyways thanks.
21 - 23 of 23 Posts
