1 - 1 of 1 Posts
Tire Wheel Vehicle Land vehicle Car
E-CLIK was engineered to enhance the Raptor suspension by delivering improved shock performance and overall best-in-class vehicle handling. The system includes three patent-pending terrain modes – Trail, Street, Desert – that are predictive to terrain and adaptive to driving style; simply pick your terrain, let E-CLIK do the rest. Taking this active system to Pro status, it includes additional tuning capabilities by offering 10 adjustment levels each to Pitch, Roll, Turn, Throttle, and Brake sensitivities, including control over rear payload, and the ability to tune front and rear shocks independently.
FEATURES & BENEFITS:
  • 3 Terrain Modes | Trail, Street, Desert - Predicts and adapts to terrain and driving style
  • PRO Tuning (Roll, Pitch, Throttle, Braking & Turning Sensitivity, 10 tuning levels each)
  • Independent Front and Rear Shock Adjustment, 10 tuning levels each
  • E-CLIK Active Touch Screen Controller features sleek styling and simple user interface, gives driver in-cab control over shock damping, mounts to A-pillar using factory mounting points
  • Improves overall traction and braking
  • Drastically reduces body roll in corners
  • Improves speed capability in rough terrain
  • Rear payload/trailer adjustments – 0%, 25%, 50%, 75%, 100%
  • OEM preset driving and steering modes remain fully functional
  • Prevents vehicle from entering Ford’s limp mode, works in unity with Ford OEM electronics
  • System designed to work with and increase performance of the OEM’s Fox Live Valve Shocks
  • Can be added to the 2017-18 Raptor applications where Ford did not supply semi-active shocks (customer needs to acquire Fox 3.0 Live Valve Shocks)
  • Easy Installation, no cutting or splicing
  • Recommend Shock Re-valving of OEM shocks for best results
  • Designed and Manufactured in the USA
SYSTEM OPTIONS:
Level 1 E-CLIK Pro System –
Electronics Package: ECU, IMU, Premium Touch Screen Controller, Wiring Harness (2017-2018 applications require Fox Raptor Live Valve Shocks, complete re-wiring and harnesses are included, all applications DO NOT require cutting/splicing)
Level 2 E-CLIK Pro System – Re-Valve Package: Includes Electronics Package from Level 1 and Re-valving Service from SDi (Recommended for best system performance in extreme off-roading)
AVAILABLE FOR:
2019-2020 Ford F-150 Raptor - SDI-SS-21530002
2017-2018 Ford F-150 Raptor - Live Valve Shocks Required, and Sold Separately - SDI-SS-21530001
2012-2014 Gen 1 Ford F-150 Raptor - Requires aftermarket Front upper bucket mount to mount live valve shocks, and live valve shocks. Includes Universal Mount for touch screen.
1 - 1 of 1 Posts
