I'm not an Engineer or mechanic, so I wish one would interject their knowledge on this one for us. You can mount OEM factory Raptor spec wheels and tires on an F150 but the inner sidewall protrudes inward further by .4" getting awfully close to the uppper arm. That's to say that you lose .4" of clearance. Highways no problem; but if you deflate your tires to assist in offroading, your rubber
may start rubbing against this. Tire poke for my combination is by no means excessive as it appears to me it's only the sidewall knobs not so much the tread. Your desired red wheels on a Raptor with Ko2's that you list have a different offset that would place the rubber much further away from the upper arm - additional clearance is great, but all that tire/wheel weight is now sort of "suspended" further out. It would be like if you placed a 1.81" wheel spacer between the OEM wheels and hub. That's a lot of spacer.
